Ahoy, all!
We've finally noticed our AIS reception has become limited to nearby vessels, within about 1 NM. And the orange error light is on, so we assumed the most likely fault is a VSWR error.
Sure enough, the PL-259 VHF antenna connector test indicates there's a short.... so we snipped the connector and tested the antenna again, yep, still gotta short. Replaced the connector, yep still got that same short. We reconnected to the radio anyway -- figuring if reception returns at all, reception distance might not be any worse than it was previously -- and reception distance improved greatly. Abd the orange error light returned.
So we've still got a known short in the antenna, need to replace it, got that.
But... that error light can indicate up to seven errors. Is it likely that any of the other six error possibilities are in play now? Or can we just cross our fingers in expectation that it's simply the antenna problem?
And is continuing use OK in the short term, even with the known antenna problem and the orange error light on?
-Chris
-Chris
