fa-50 red light after update
abdohassan
Hello, I am facing a problem after updating the ais fa-50 device. There is a continuous red light and the computer does not see the device after entering the IP to enter it. Is there a solution?
I would contact your local Furuno Distributor and they should be able to walk you through the reset procedure using the hardware.
Otherwise you can send it to your local Furuno Distributor and they could check to see if it is able to be recovered.
A solid red light indicates an error in the memory or transmit circuitry.
