I have a ETR-6/10N Network Sounder hooked up to my Navnet VX2. I just did a major overhaul on my boat, removing all the electronics, wiring, motors, fuel tanks, ect.
Its all back together and everything is working except for the Sounder.
I was having intermittent problems before the overhaul while fishing, where it wouldn't work most of the time but would randomly start working, then stop working. I thought it was a low voltage problem because I had an alternator going out on the battery that ran the electronics.
The module led indicator light will blink for 3 minutes and then stopping with a solid green light as indicated in the manual as its not reading the gps or radar, while the gps and radar are both on.
What do I need to look for to troubleshoot this problem. The only thing I can think of is maybe a bad network cable or bad connections in the network cable ends?
Thank you for any help.
CaptJeff
CaptJeff
