Ethernet Hub 101
paymanmd
is there an alterntive to the furuno ethernet hub 101. at $800 i would like to explore something more reasonable priced but would be compatible with the tzt3 and drs ax radar.
thank you
thank you
Really you can use any ethernet switch -- but stay away from the "smart switch" types. The Netgear GS108 and GS105 (8 and 5 port versions respectively) are a nice sturdy units that are native 12V. Just cut the power cable off the 110V transformer and connect it directly to a 12V fused supply on the boat. They are 1/16th the cost of a HUB 101 and actually have faster data speeds. They are also very reliable even on a boat.
