EBL offset/off center with a TZtouch or TZBB
We are looking to outfit a new build and am looking at the radars. We currently have some and older 1935, a couple of newer 1935's, and a 1942C in our fleet. What I am looking for is the ability to use an offset/ off center EBL in a newer unit. I have found that the new 1935 still has this feature but have yet to be able to find it in the TZtouch or TZBB manuals. Is it a function in the newer TZ line or not? Thanks for any info.
The TZT products are primarily MFD plotters with the ability to add radar.
Although there is no floating EBL/VRM, there is the ruler feature that allows measurement of range and bearing between any 2 points.
You can find it on the plotter display and can be used when in radar overlay.
So, just so I'm clear on this... With a TZ system I can not move the cursor 90 degrees off my starboard side and have an EBLline running straight up at zero degrees forming a parallel line for line up and reference purposes while in radar mode.
Thanks for the reply.
