Customer has a tzt1bb, tzt2 and an open array networked. is it possible to independently change radar ranges? Presently when you range one the other unit follows. Doesn't happen in the chart screens. Thanks, Davem
Some DRS units offer duel range where you can split the screen into two radars and then the second range can be used. The first and primary range will be the same on all displays showing the radar. (They will be in lock step)
On my TZTL12F I've created a dual split screen with two radar displays.
While my left side has a valid radar signal and displays everything all right,
the right one of the split displays radar screen but with the message "NO RADAR".
According to the TZTL12F manual this should be a valid set up giving me dual range radar functionality. What is the reason for this not working as described?
I'm using the Ethernet connected DRS4DL.
Regards,
