I am planning to install a DRS4D-NXT on my 25' center console. My boat has a cobia tower where you climb up through the front of the t-top. The tower also folds forward, so I don't think it's possible to install the dome on the front of the t-top. I have a VHF antenna on the starboard side and my SCX-20 on the port side. If I were to have a plate welded behind the pad where you stand and install the dome on a 6" pedestal, would the radar function well being that far back on the t-top? The last 18" or so of the top pitches downward. Any better ideas? I know shooting through the tower legs isn't ideal, but I often remove it if I'm not hunting for cobia, so usually won't be an issue. Tracking weather will be the primary use. Any other ideas? Really hoping I can figure something out that won't cause me to give up the cobia tower.
Maybe if that idea won't work I could have a small radar arch fabricated that would install in the bases for the cobia tower and I could just switch between the two as needed. Is it possible to have the wire installed in a way that it could be unplugged and removed easily?
