I'm in the process of installing a new TZT3 and DRS4D-NXT. The supplied radar cable is large/stiff and will be difficult if not impossible to run through my T-top tubing. Separate ethernet and power runs would be more flexible and easier to route. Is this an option? I'm sure I could find separate shielded ethernet and shielded power cable (if pwr needs to be shielded). I'd skip the external pigtail connector and bring the pwr and ethernet lines directly into the dome with appropriate sealing and strain relief.
