Drs4d fuse location
The DRS4D itself gets it's power (48Vdc) from either the MFD or power supply, which either will have a fuse.
Tryjng to connect older drs4d to my new tztouch2, was told to update software .power from psu 17 got 48v at radar.downloaded program on laptop and followed instructions but can t get download countdown to start.get to sceen with ip addess then cut power to radar to reboot but download don t start.
If it was working before, it should be upgrading, unless the voltage got reversed and something got damaged. Try re-powering the power supply before starting the PC program. There is a window when the older DRS software looks for an IP address and maybe you are somehow missing it. If it still doesn't work, I would recommend sending the dome into the service center to have it evaluated. It is VERY important that your PC have no anti-virius programs or firewalls up that might block the programming. You might also try using a hub in the middle of the connection or using a different network cable.
Dome worked fine before did shut down antivirus and firewall .The window with the correct ip address comes up and after reboot won t show download progress.gonna get tech to check dome thank you for advice.
