I have a DRS25AX and strongly recommend it. I forget the minimum proximity that it will show a boat but this is an inconsequential 'benefit' of the solid state radars. Even in jam-packed mooring fields it shows the boats very close by--I see absolutely no practical benefit to showing targets any closer than the 25AX does. You're not going to use a radar to steer around a target 10' off your bow even in the thickest fog and darkest night. I think the implementation of the doppler processing (need to be on a special screen) eliminates the practical utility of that feature as well. ARPA with the 25AX is outstanding as well--it is impressive to see how well the course & speed match between AIS and ARPA. I don't know if the AX is any better or worse than the NXT here, but it could not be better in a practically significant way. One thing that could be improved is the automatic acquisition of targets. Sometimes it seems to grab them, many times I am manually acquiring targets, especially at sea when it's been running for a while. Perhaps the NXT is better here, but they are likely running similar software with similar results, but that's a guess.
And the benefits are significant in my opinion. The combination of massive power output and truly amazing receiver sensitivity combine to make for a best-of-breed instrument. Bird finding is off the charts great, head and shoulders above anything else I've tried, and I've tried and owned a lot of different radars. Flocks, single birds, small, large, in close, out at distances I'd never bother running after them, it is exemplary, and the info is displayed in a way that is extremely easy to tell what you're looking at. I can tell with ease if it's birds vs. boats, small flock vs large, etc. No guessing. It's ability to paint distant shorelines with awesome detail while simultaneously showing any target of interest in close is awesome. Dual range is nice when the fog is crazy thick (happens a lot around me), but generally isn't even necessary. The auto settings work extremely well so you don't have to mess with it if you don't want, although I do like to play around with settings. I think it is the best recreational radar ever made.
