All Furuno domes are 160mm x 160mm
The open arrays are 200mm x 200mm but they did have an older pattern back in the 1980/70s. Anything in the last 25 years would typically fall under the measurements above.
As long as your mount has clearance for the larger dome (1" bigger or .5' more each side) then you should have no problems. The bolt pattern is the same.
