Display Flickering
Syed Owais
We installed north invent 24inch display to TZT2BB processor with HDMI to DVI.D 3M cable but display is flickering some times.
Any solution.
It's hard to say what's causing it, but the easiest thing to try is another cable. If that doesn't work, try another monitor. Not all cables and monitors are built the same.
I encountered an issue with the Furuno DS-50 speed log. The display unit started flickering and showing "000" on the screen at that time speedlog data connected equipment also not getting the speed data.To troubleshoot, I replaced it with another display unit, but the problem persisted. Upon opening the display unit and disconnecting the connector attached to the LCD, I noticed that speed log data was successfully transmitted to all connected navigational equipment. What could be causing this issue? Please advise.
if after disconnect the transducer from display its mean transducer has fault or transducer wiring may be short.please check by multimeter.Also check the ground wire of display is properly connected or not.
The DS50 is a commercial product and is not supported on this forum. Please contact your local dealer or distributor for support of commercial products.
