The connection diagram (C13520001-H) in my OPERATOR'S MANUAL show the WAGO pin numbers in the opposite order from what the labels in the DFF3D show. For instance: TB1 the 4-pin WAGO connector is shown in the drawing with pin 4 located next to the TB2 connector. However, the numbers on my TB1 (4-pin WAGO connector) run in the opposite direction such that pin 1 is next to the TB2. In other words, if you renumbered the pins in the drawing, such that the numbers started at the bottom of each connector and increased as you move up, the drawing and my machine would match.
I have no idea whether it is proper to install the wires according the physical locations shown in the drawing, or according to the pin numbers shown in the drawing.
