stratboogie
So, last week when I was out I started getting the "torch beam". After looking no here it seems to be a grounding issue. I took down the box and looked at the wiring for the transducer (I did not do the install of my 3d system). Everything looks right except the bare wire is connected into the same connector as the black wire. On the diagram it has common. Is this correct? Also, the installer did not install the clamp with the shielding. Anyone know what size screw those clamp holes are? I will have to make a clamp. Also, the earth ground is not connected. Do I need to connect that to my negative motor battery?
Thanks in advance
Thanks in advance
