Snips:
Here is a picture from the DFF-1 with the B45 taken at Georges Bank. Marking tuna very good on the low side. Missing some on the high. This is the unit/transducer I want to upgrade to wider angle on both frequencies.
The second photo is from the FCV 1150 with the R209 taken on the same trip. This is just marking bait. I believe I had the frequencies set at 40khz on the low and 160khz on the high.
This is a fantastic machine and transducer combination. Marks bottom, bait, and thermoclines very well. I am curious to understand what parameters are changed when the unit is in the Squid transmit mode?
Still trying to decide what would compliment the FCV 1150 better. The DFF-1 with a 556TID-HWD or the B275 with a DFF1-UHD or DFF-3
With the B275 connected to the DFF-3 what is the frequency range? The DFF-3 manual specifies 28-200 kHz for the unit but I am not sure what the transducer will accept. My guess, based on the CHIRP Specs, is 45-62 on the low and 150-200 on the high.
Thanks for your help
This is a fantastic machine and transducer combination. Marks bottom, bait, and thermoclines very well. I am curious to understand what parameters are changed when the unit is in the Squid transmit mode?Still trying to decide what would compliment the FCV 1150 better. The DFF-1 with a 556TID-HWD or the B275 with a DFF1-UHD or DFF-3
