Date is Bad and I can't change it
Chubbi
I can't change the date on tztoush 2, I already changed the GPS source to ais It still shows that it's 2006
You will need to change the Date/Time Source.
If you already did that, what is your date/time source? Can you post a picture of your sensor list?
Appears and disappears
Change from GPS200 to fa-170 Continued in 2006
Not recommended to be using your AIS unit as your time and date source.
Why are you not using the GPS source like the GPS200 or the what appears to be a sat compass SSC200 as your source?
It looks as if your GPS200 has "rolled over" which causes it to output bad dates and becomes less accurate.
The SSC200 is a solid state compass and does nothing with GPS so that won't help.
Your FA170 is outputting the external data it is receiving as the internal data is for self timing and verification.
You should contact Maretron to see if there is a software fix for your GPS antenna or you could replace it with our GP340.
I agree, Maretron might have an update for the GPS to deal with the GPS roll over. Your devices are older and GPS rollover has occurred. The Furuno AIS likely has older software in it as well. In 2020, newer software was released for the FA170 to extend its rollover to 2032. As FishTech says, your main GPS source should be either updated or replaced and I would also recommend getting your dealer to update the FA170 software as well.
