Current tide data
joewyz
How do I check what tide data I have? I downloaded it to an SD card, but I can't find the procedure for loading it. Any help would be appreciated.
Joewyz
CarinaPDX
You load it in the same way as a new chart. First delete the old file, then install the new one (version 10 at this time) from the SD card.
If you haven't done so yet download the current version (H) of the Operators Manual from the Furuno product page, as it explains the chart uploading procedure in section 13.7.
Greg
CarinaPDX
Here is the link for the manual: http://www.furunousa.com/ProductDocumen ... al%20H.pdf
Also, new NOAA raster and vector charts were recently released so you may want to update them at the same time. If you haven't been keeping up then there may be other files that need updating (particularly the change from US 3D to North American 3D, and the update to version 2.11 of the system).
Greg
CarinaPDX
Attached is a list of the current (free) charts for NN3D MFDs. It should help you make sense of the files your MFD shows installed, and you can quickly determine if you are current. I fill out the 3rd column with an "X" to identify those that I have installed. I have made no attempt to list the non-free charts so you may have other charts installed/unlocked on your MFD.
Greg
  • ChartListMar2014.rtf
I’m putting a couple of MFD’s into service in here in Europe and from what I have seen so far am disappointed at the poor display of Tidal stream information on European charts.
I see there is high definition tidal data available from Maxsea but am not sure how it interfaces with the Furuno MFD, can it be uploaded?
I don’t want to run a laptop all the time, any advice out there?
CarinaPDX
I find tidal current files for several EU countries on the MapMedia.com website, and they show compatibility with both MaxSea and Furuno NavNet3D. AFAIK both MaxSea and NN3D use the same MapMedia format, and when both NN3D and MaxSea exist on the same system they can share access. As I don't have MaxSea I haven't dealt with the details of sharing. For the MFD8 you can download the tidal current files, as with any chart file, load it on an SD card and install it on the MFD8. You will also need to purchase the DRM file (requires your system ID) and install that as well. If you plan on using it with MaxSea as well then you will need to research that (or wait until someone more knowledgeable can respond).
Good Luck,
Greg
CarinaPDX
I was curious so did a little research. The MaxSea TZ Explorer can stream data to the MFDs, but must remain connected. It does not work from MFD to MaxSea. See: http://www.maxsea.com/support/faq/can_t ... he_network
When installing two MFDs in the same network, it appears that both MFDs get the same System ID and thus should be able to install and unlock the same chart and DRM files (if I were you I would confirm this before acting on it).
I hope this helps,
Greg
Thanks for your reply Greg... Excuse my ignorance but what are DRM files? Rgds Dave
CarinaPDX
Sorry for the confusion - I meant the unlock keys. I'm not remembering whether they are in a file or just a text string. "DRM" means Digital Rights Management, a generic term for the technology for controlling access to copyrighted works. In this case the unlock keys are created specifically for your System ID and a particular edition of a chart package when you buy the key. Although MaxSea uses the same MapMedia 3D chart file format as Furuno's NavNet3D and TZ MFDs it needs its own key matched to your copy of MaxSea. (The chart file is encrypted, and these keys prevent unauthorized distribution and use - the chart files can be downloaded but can only be used with the appropriate key for the Furuno system or MaxSea installation.)
Greg
