How can I get the latest C-Map software to load in a Vx2 display that was originally Navionics?
Background: I had a lightning strike a couple of weeks ago. Both RDP-149 displays survived, but I lost the Data-4 port on the main display, and the dBox display got a bit garbled. Turns out the NMEA port UARTs are the most sensitive thing in my electronics setup -- I lost a total of nine of them on the boat.
All the NMEA ports are on the main board, so I bought a used RDP-149 with screen damage (readable but not good) as an organ donor to scrounge the main board. (This is not my first surgery on an RDP display; something of a veteran now.) I did not realize it until later that the donor display was a Navionics unit.
No problem, I thought --- back when I had original NavNet displays (before I upgraded), I was easily able to switch a display from Navionics to C-Map using an Ethernet cable and a PC. I did not realize that with Vx2, Furuno has apparently made the process more difficult.
I have the proper small SD card, and an Ethernet cable, and I can make serial cables. I just need to know how to get 4.03 C-Map into the unit before I pull the boards out.
Donor display is serial 4345-1199. Current program is 195002301.08.04
Thanks.
-Sean
Thanks.
-Sean
