Can't shut of Sounder Auto Range
Lunderic
I have a set up with 2 TZTL 12 Displays. For some reason I can't shut off auto range on the sounder on either display. Auto Range is Toggled to off on both displays. Running 4.01 software on both. Any suggestions?
Thanks,
Eric
Lunderic,
Is the Auto Range setting set to "on" and not switching to "off"?
Or is the Auto Range setting showing "off" and your range scale is still changing as if it is auto range is still on?
Have you tried to reset the sounder settings? Press the home icon, select Settings, and then select Sounder. Scroll all the way down to the bottom and select "Reset Default Settings". This will put just the sounder settings to the factory default. Perform a reset and see if you are still having the same issue.
