calibrating target on my radar.
rodneymeyers
I have a tz3 with drs4d-nxt radar. While running to the ocean in a calm bay I can head straight at a bouy ahead and the target shows up on the radar 5-10 degrees off to my starboard side. How can I adjust it to be more accurate.
Good Afternoon,
While on your home screen go to setting and then select Radar about mid way down the menu you will see Antenna Heading Align. You can enter a positive or negative number depending on which way you need the correction.
