bbwx4 and tzt2bb
thecfan
i had the bbwx4 working properly with the tzt2bb before i installed software upgrade 8.0. Now it doesnot communicate no sea water temps no weather info. looked in setup have radio id and an IP address. Have reset the bbwx4 via Sirius 3 times to no avail. Their tech says ball in your court.
It would be best if you call tech support from the boat. (410-479-4420 or 360-834-9300) Whatever the issue it isn't related to the software update unless you failed one of the final steps in factory resetting the unit after programming. I am sure they will get you back up and running quickly.
Similar threads
Replies
6
Views
8K
