BBF1 Transducer Compatibility
aquabelle
I have an older 8-pin 520ST-MSCF triducer installed. If I use an 8 pin-to-10 pin adapter cable, will I be able to successfully use this older triducer with a BBF1 (ETR-6/10N)?
Aquabelle,
Yes, that transducer will work if you use the adapter cable.
I have the same triducer 520ST-MSCF, is it compatible with a DSM 300?
Thanks,
Zarka-
The DSM300 is made by Raymarine. Your will have to contact them to determine compatibility.
They also have their own forum on-line.
Thanks for the answer. Where can i find the wiring diagram for the 520ST-MSCF transducer.
Tried to look on furuno website but no luck..
Thanks,
Zarka,
What model of sounder was the transducer connected to? Normally the pin out of the transducer is in the back of the sounders installation manual.
