I've done a lot of searching and it seems that there is a consensus regarding a general dislike of the B164 transducer. Seems like all the recommendations go to the B260. Yet, the only combo transducer offered for the DFF3D contains a B164 along with the 3D array in a B260 housing. If the B164 is so bad, why put it in the combo transducer?
Looking a the Airmar data for the various transducers, they typically list in a Good-Better-Best manner based on the "Q" of each offering. Here's the 50/200 Q's and Beam Width's of several TDs from the Airmar publications.
-TD-------Q---------BW--
P66-----24/30---45/11---------GOOD
B117----28/30---45/12--------GOOD
B258-----9/15---15x21/3x5---BETTER
B164-----7/17---22x20/6x6---BETTER
B260-----8/8-----19/6----------BEST
Now looking at just the B164 and the B258, they seem pretty close with the B164 a bit better at 50kHz and the B258 a bit better at 200kHz. But the Airmar literature is still confusing in the comparison descriptions of the P66, B164 and B258. Quoting from the Airmar TM258 literature are the following comparisons:
Comparison TM258
Model------Rating-------Performance Increase
P66----------Good---------Benchmark model for comparison
TM258-------Better--------25x more sensitive at 50kHz and 16x more sensitive at 200kHz
TM260-------Best----------50x more sensitive at 50kHz and 13x more sensitive at 200kHz
And the B164 literature has the following comparisons:
Comparison B164
B60(B117)-Good---------Benchmark model for comparison
B164-------Better--------6x more sensitive at 50kHz and 2x more sensitive at 200kHz
SS264-------Best----------50x more sensitive at 50kHz and 13x more sensitive at 200kHz
And now the really confusing part to me is that the P66 is slightly better than the B60(B117) and yet the TM258 is 25x/16x better than the P66. Now looking at the B164, it's only 6x/2x better than the B60(B117). The 50Khz Q of the B164 is better than the TM258 so how can the TM258 be 25x better than a P66 at 50Khz?
If you just consider Q it would seem the B164 should be more along the lines of 25x better than the B60(B117) at 50kHz and more like 10-12x better than the B60(B117) at 200kHz. I've always considered the B258/TM258 to be a really good transducer so it surprised me to see a lot of non-positive comments about the B164 on the board. Yes, in a perfect world we would all run a B260 with a high speed fairing with our DFF1, but sometimes we don't have the space for it.
Lots of blah, blah, blah above but it's necessary to get to the point of the matter. I'd like to get some better deep water performance and need to look at options for replacing the B117 with a 1kw transducer. In looking at my realistic options for a thru-hull transducer I can either keep the B117, replace the B117 with a B164, or replace the B117 with a 165T-B54 (no fairing) and use a TM260 instead of the TM54. I don't have the room for a thru-hull combo transducer as I'm limited to about 2-1/4" total height.
Thanks in advance for any thoughts/advice.
Comparison TM258
Comparison B164
