Autopilot speed detection not available
Which NAVpilot model are you using?
Have you configured the pilot "sensor setup" to look at that source under SOG (speed over ground) setting?
I have the 711C autopilot and the PG 700 heading sensor with a TZT 12 and TZ14
I havent looking into the sensor set up. Is that on the 711C or on the TZT 12 settings?
It is a screen in the 711C. You will need to select your GPS source as the source of speed (SOG) in that screen.
See section 3.8 in the Installation Manual. I have provided a link below (for your convenience):
Awesome, thank you. I:ll try to work on it today and see if this works. If not i"ll be back with more questions. LOL. Thank you
