I need to know the distance from mounting bolt to mounting bolt on the underside of a DRS4W. I want to see how wide of a aluminum sheet I need to make a radar mount. TIA
The mounting hole (underside of DRS4W) bolt pattern are 160.5mm = 6.318 inches from each other. The outline drawing is located in the back of the Operators manual on page 31/40 pdf or on page D1 towards the back of the manual.
Thank you, I looked at the manual and wasn't sure of the dimensions listed. I figure 8" wide would give it enough support for the unit on a 1/4 thick piece of aluminum.
Hi - I have a 1730 model on my boat mounted to a Garhaurer radar mast. I'm now looking at the DRS4W model. My question is if the mounting hole pattern is the same? Thank you.
