711C Rudder Center
  • Thread starter Thread starter zundels
Z
zundels
I am getting some excessive rudder movement with my 711c/TZT14 and I think that my rudder may be slightly off zero. (I have the unit running in economy mode, have adjusted the gain down, adjusted manual parameters etc.) Is there a quick way to check/adjust the rudder center when I am running on a plane?
Is there a way to set the center without performing a full sea trial?
It is in the Sea trial menu. You must be moving/driving straight when you set it. You don't have to conduct anything but this to set set center. No compass cal or other sea trial item needs to be redone.
