Kickinback
I have about 10 hours on a 711C autopilot hooked to a TZ2. Up until know it has worked flawlessly. Last time out it just went off and would not turn back off. The TZ2 reported that it lost connection when it went off. I turned everything off and tried to restart with no luck. So other than connection to the TZ and the ground what else should I check before I pull it out and send it in? I had it installed but it's moored a long way from there. I read there is a fuse to check but the manual suggest having a professional check it. Suggestions?
