I downloaded & followed instructions, but have not even got to 1st base. Downloaded to SD card, checked & the files are there for Part 1, install in TZT2 & it goes through the steps as if nothing was inserted.
Thank you for that reminder. I remember that on my last unit. But, I used the 128gb in my unit to upload charts, I figured it would work. I guess that is my next try. The old 32gb used on my last unit, wont fit this one.........uhhhh!
O.K. the 32gb card was the issue. I got part 1 to load. Part 2 is not loading, I formatted & loaded the part 2 files 2x's & the machine boots as normal, not recognizing the USB. The Flash drive card has a light, & it comes on the flash drive, but the TZT2 is not seeing it
It might be time to buy the software update kit from your dealer (p/n TZ2-SOF-6.21) for the TZTL. The kit has the instructions and both Part 1 and Part 2 pre-setup with good working memory.
I have not loaded the new software yet, but I had the same issues loading 5.3
I used a SanDisk, Ultra Plus, 16 GB micro card. The card type made a difference.
Yes, has to be a 32gb card, not sure about brands. Called Furuno because Part 2 was not loading. Kenny told me to use a different Flash drive. So, I bought a new one & boom, it is loaded! Also as per instructions, reset everything. All is Well!
