1870f and Airmar Tm260 transducer
Rob
Hi all please would any one have the wiring diagram for this transducer to match this sounder
It seems to only use the white ,blue, black ,brown and earth wires but not sure of the pin numbers
on the plug
Pin 4-White (Temp)
Pin 7-Brown (Temp 0V/ground)
Pin 8-Blue (Xdcr +)
Pin 9-Shield/Bare (Xdcr Shield)
Pin 10-Black (Xdcr -)
Pin 4-White (Temp)
Pin 8-Blue (Xdcr +)
Hi thanks very much simpler than i thought. Just one question do you need to fit the bare shield wire to pin 3
Bare shield wire with the transducer wires goes to Pin 9. By the way...it should be an uncoated wire, not the actual shield of the cable. Pin 3 is for a speed wheel connection.
