Hi. I bought a used TZT3 with DFF3D and a 165T-B54, which I need to install on my 19 feet RIB, which needs to be trailerable. For such a small boat I'm excluding using the fairing block, so I'm considering these options for the transducer:
For the in-hull mount I'm worried about attenuation because of the sound waves having to pass the fiberglass keel, at an angle for most of the beams. A local expert says that, as the fiberglass shouldn't be really thick in that point, this shouldn't be a problem; but he doesn't have direct experience with the B54 in that position. Is there anybody here who can tell their experience?
Last, mounting it on the transom. I've been told that there is a very high risk of water leaking through the hole where the two cables come out of the transducer, but I wonder if that can still happen if I use a good amount of sealant and wrap the end part of the bronze and the cables with a waterproof conduit.
Any insights would be highly appreciated! Thanks
Dan
- Mount it flush on the keel
- Mount it in-hull, building a reservoir with glycol-water mix
- Build a custom transom mount, and put it on the transom
Dan
