DFF3D Initial setup
DFF3D Initial setup
Postby flowmotion » Mon Jan 29, 2018 6:11 pm
UPDATE: I requested this information from technical support. It is not currently documented anywhere.
EQUIPMENT: TZtouch2 mfd, 165T-B54 transducer (thru hull mount in transducer flat)
QUESTIONS: I need clarification on the inputs for the DFF3D intital setup menu for the transducer.
Motion Sensor Menu.
1) how do I set the roll sensor offset? this parameter is not defined anywhere.
2) same question for the pitch sensor
In summary, the manual does not define some of the required parameters.
flowmotion
Re: DFF3D Initial setup
Postby Johnny Electron » Wed Jan 31, 2018 7:46 am
You only need to adjust the offsets if you are using a SC30 sat compass or similar. If you are using the sensor in the transducer, don't change anything.
User avatar
Moderator
Moderator
Return to NavNet TZtouch2
Who is online
