Wiring Radius
neils
I am looking to install a TZT12F at my upper helm. I have the mounting dimensions from the installation manual. This shows a depth of 115mm and a clearance behind the unit of 150mm. The install is on custom navpod with a sloped front and back - so it has a trapezoid cross-section. To avoid stressing the cables - what is the maximum radius I should install the cables at? Do I need the full 150mm clearance behind the entire unit? This will be the slave unit on my system. The chart master unit will be installed at the lower helm - if that makes any difference. The face where the TZT12F is to be installed is 265 x 410 mm. See attached pdf for the navpod.
  • navpod.pdf
We are not going to recommend or condone anything other than that 150mm. A lot goes into that measurement. Things like, space to allow for cooling via airflow, access to the chart card, as well as the bend radius of various cables. The power cable is going to be the one that needs the most space.
