I have some questions regarding the following Furuno guide on this topic:
https://www.furunousa.com/-/media/s...net_tztouch2_and_yamaha_gauge_information.pdf
It all sounds really good but I have not been able to get any information from Yamaha regarding this setup so I'm checking to see if there is a Furuno expert on this that can help.
I have dual 2006 Yamaha F150's and a Command Link system (square gauges). I've used the Yamaha MAR-GTWAY-ML-09 for many years to provide engine data to my previous NN3D system. With my new TZT9 and TZTL12F system it seems like the TZTL12F is sensing the MAR-GTWAY-ML-09 gateway and displaying the Yamaha Engine tile that is shown on page 5 of the bulletin. Yet when I select this tile there is no data displayed. I'm assuming it's because I would need to replace the MAR-GTWAY-ML-09 gateway with the 6YG-8A2D0-00 gateway mentioned in the bulletin.
I can get traditional instruments to display engine parameters on both MFDs which indicates the MAR-GTWAY-ML-09 gateway is working and passing data to the N2K network.
Since the 6YG-8A2D0-00 gateway (interface unit) is another $300 to replace something that is working fine I would like to confirm that the 6YG-8A2D0-00 interface unit works with Command Link as described in the attached Furuno bulletin for the TZTL12F and that it will work with the TZT9 for traditional instruments to display engine parameters.
