TZT9 able to monitor fuel usage
BigEd
I was looking to add something to monitor the fuel usage on my boat so I can know how much I’m using does the TZT9 capable of doing that and how or what do I need to do to make it happen thanks
On the newer TZT9F you can arbitrarily set your fuel and the device can "guesstimate" your fuel usage rate, but on the TZT9 to display the fuel level on the screen "fuel flow" or "fuel level" data must first be supplied via a NMEA 2000 compatible sensor such as Maretron's fuel sensors (there's many available options). :cool:
Once you have a data source, you can display a pump icon on the route where it is predicted that the fuel supply will be exhausted by going to [Menu] > [Routes} > Select [ON] in [Fuel Max Range].
Hope this helps. :sail
ref. (PG 5-16 See Sec. 5.11 Fuel Level) in the Operator's Manual: https://furunousa.com/-/media/sites/fur ... manual.pdf
- Maggy
