SCX 20 off sets
Yan
Hi,
I set the offset for pitch and roll in the scx 20 settings. I see I can set the same parameters when i configure the transducer. Will this be a double correction? One in the scx 20 and one in the transducer?
In the DFF-3D transducer setup menu, there is a setting for "motion sensor source" that allows you to choose between the SCX-20 and the internal sensor in the transducer. The system will use only one at a time so I don't think there is any possibility of a double correction. Generally it is preferable to choose the SCX-20 as the source because it is faster and more accurate,
