I recently purchased a boat with a 1944C-BB unit. On the last trip when selecting TX for the radar the ENTIRE unit shuts down. Restarts fine, chart plotter function works great but when I select TX for the radar it shuts down the whole unit. I checked voltage going to the processor and am reading 13 VDC. Opened array unit and see nothing obviously wrong. Array will rotate approximately 1/4 turn before shutting down. If I disconnect the connector at the processor going to array and select TX it does not shut down the unit. Indicating that it's an issue with either the lead from the processor or the antenna assembly. Another observation noted and not sure if it's related, but when the radar was operating normal it sometimes took a long time for the overlay function to be enabled. Any ideas or suggestions would be greatly appreciated.
