So I'm planning on installing dual TZT3 16 screens. I will want to run either 3 or 4 transducers through these units. Likely B175HW, M, and H. Possibly also an 'L' as well but I haven't decided yet.
I'm curious how this all works together. I have a hunch that you can split the screen between two units plugged into one TZT3 but cannot do so with transducers that are plugged into different screens? This is the way it is with Garmin anyway.
For instance, if I have the HW and M plugged into TZT3-16 #1 and let's say the H and L plugged into TZT3-16 #2, I am guessing I can split either display to show HW & M at the same time OR H & L at the same time? But not, for instance, HW & H at the same time?
Also, how easy is it to pause sonar transmission for any single channel? Let's say H and HW are interfering with each other...can you pause sonar transmission on a single channel? Or do you have to pause an entire unit? Or do you have to pause all channels in all units?? Not familiar with this type of control on these units.
