"Maximum Track Points Reached" alert
ELGATODOS
TZ touch 2
There are no more than 2 track lines or trips on the entire unit and I get this error in yellow on the screen.
How do I fix the issue?
If they are trips which the track points are dropped at very frequent intervals then you may have indeed used up all your track points. This can be normally fixed by adjusting the tracking method and the interval. I recommend you open a support case with Tech Support and provide an export of your track file so it can be examined.
