Hardware: Battery Level Alarm
jeminwy
Got this alarm on my Tztouch. Not sure what it means or what to do about it. Boat battery levels are good at 13.3v
Assuming this is a TZT14, TZT9 or TZTBB, this message is regarding the internal battery. It should be replaced by an authorized Furuno USA dealer. Here's the info from the Operator's Manual:
I am cruising. Finding a dealer not easy or convenient. Is it possible to do the replacement yourself using the correct battery.
Jerry
No. There are too many cables/connectors and things that can be damaged when taking the display apart. It would be possible to lose the use of this equipment if that happened. For now, I would just ignore it until you get to a place that you will be for a while and have it changed then.
