I would like to connect my Furuno FCV-588 on the NMEA2000 network to interact with my Garmin 922XS and work with it.
The intention is to exchange coordinate information between them and score new points in Furuno and automatically transfer to Garmin 922XS.
I´ve got an IF-NMEA2k2 to convert NMEA0183 furuno FCV-588 to NMEA2000 network but it didn't work.
I connected IF-NMEA2k2 to a NMEA2000 networking powered by 12v from the boat and, the other side wired with Furuno with the connections: Pink(TDA) to Yellow(RDA) /// PINK (TDB) to Green(RDB) /// Blue(RD-B) to Blue(TDB) /// Blue(RDA) to White(TDA). In the Furuno I set NMEA 0183 version 2.0 or 3.0, NMEA Port = IN/OUT, NMEA Output = ON, Waas Setup = Off, TLl Output = TLL. But after making all this connection and setting up the equipment nothing works. In the MANUAL IF-NMEA2k2 says that the power LED flashes yellow when the box is powered, but nothing lights up when the box is connected to the NMEA2000 network.
Does someone can help me with this error? How can I test the box IF-NMEA2k2 to make sure is not damage?
Thanks in advance.
Marcos.
Thanks in advance.
Marcos.
