Im Installing a new DRS4W .. Radar on top of my radar arch. Ive pulled the cable through and into the fuse block compartment.Ive hooked the red wire w fuse to the new switch in the switchboard  I've connected the blue wire back  to the ground.  I've capped off the wrap ground for now until I install a through hull water ground. or research a better way ?I checked the plug that connects the radar for current and it lit up . I turned off the power and connected the plug to the radar and turned power back on from the switch to the radar . I didn't hear any on or running  noises .I opened the app to see if it made any connection And it said no . Is there a waiting warm up period .Should I hear the unit running  Where do I go from here Thanks Bob
