DRS4D-NXT - Channel Mode
mattology
I remember reading somewhere that Channel Mode was going to be introduced for the DRS4D-NXT. Any updates on this?
If your TZT3 has the correct software version to allow updates by wifi. Can this radar update be loaded through the TZT3 by wifi as well as the thumb drive method? If so, could you give a quick recap of how to do it. Thanks in advance
The sensor update package has to be run on a TZT 3 using a USB drive as far as I know. With the USB drive in the connector, go to the Initial Settings menu and then select "Update Network Equipment" and the program will start running. It will identify the network sensors and the versions and the items for which there is new software.
One thing to note that is a quirk of the sensor update software is that you have to create the USB drive using a Windows computer. Even if you use a drive formatted as MS-DOS Fat 32 on a Mac, the updater will not run properly. What's odd is that the TZT 3 unit software updates work just fine when downloaded on a Mac.
