DFF3-UHD With B265LH And Timezero
CapEgale
Is it possible to run Cm265LH on DFF3-UHD?
It says 2 kW compatible in the Transducer options. Can we run the Transducer by reducing the power?
Also is it compatible with DFF3-UHD Timezero?
I don't know if the DFF3-UHD has been added as supported sounder on TimeZero. You would need to ask their support that question. I can confirm you can NOT run the CM265LH (1Kw) on the DFF3-UHD (2/3kw) fish finder.
