Hello,
I just installed a new FCV587 with B164-20 transducer to my Parker 2110. Also added was a Lowrance HDS7m Touch chartplotter. To confirm, are the NMEA 0183 connections below correct? Presently I have not nav data showing on the 587. Also, the Lowrance has a setting for NMEA0183 sentences which include MARPA TLL TX. Any chance this is useful for the Mark feature on the 587? Otherwise, should I use standard GLL for GPS data to display on the 587?
Lastly, I cant seem to enable the water temperature to display on the 587 screen, I have selected "Inside" for the temp setting, assuming that the B164 with integrated temp is "inside" and outside means a standalone mounted temp sensor, correct?
Kirk
Kirk
