cameron":39kj96vn said:am I needing something else
cameron":36yukvti said:I am looking at the order when purchased, there is a 12 pin pgt the installer used if this helps clarify anything.
cameron":18op3eol said:Renamed, confirmed, the port screen is the master screen and the ducer is plugged into that one.
mattology":32w46ei7 said:I was under the impression that the TM265LH elements were only bottom discrimination compatible with the DFF1-UHD, not yet with the TZT3 internal sounders. A later update is supposed to add bottom discrimination capability to the internal sounders.
source: Page 9 , Overview of changes made to TZ Touch 3 with V2 software .PDF
cameron":12kixu86 said:How much more detail / how much better is the UHD 1 sounder over the internal 1KW chirp that comes with the tzt3?
