G
gritta
I am looking only for bottom discrimination, I want to see tails under bottom line.
I want to be able to recognize flat hard bottom from mud or sand only on primary echo return, looking for its tails (composition and thickness of them).
The machine is of another brand (1kw), but I am interested on these four transducers:
- CA50/200 1T (or 12M)
- 200B 5S
- 200B 8B
- 526TID (low profile, tilted element)
My range of bottom depth is 300-500' (100/150 meters). Which would do the better work? I was looking for a transducer with an high Q factor and narrow beam, it seems that better shows tails. I dont't found any technical data in Furuno house for Q, but I have only read old posts here on forum....
Putting on a 2kw transducer on 1 kw machine, can I have any improvement? Better clean signal?
Thank you very much
- 200B 5S
- 200B 8B
Thank you very much
