B260. DFF1 UHD
No the B260 is a fixed 50/200 transducer and can not be CHIRPED with the DFF1-UHD true echo Chirp fish finder.
Thank you for the reply. I have discovered the transducer s connected to the FCV100L are single element 28 and 200 Hz. 2 and 3 kw. I am going to connect to the NavNet TZ Touch network using an ETR30N. This should work? Correct. Then next year install a chirp transducer and a DFF1UHD
FCV1100L
The ETR30N (aka BBFF3) is not compatible with the TZ Touch network
