J Jcapuano New member Sep 7, 2023 #1 What should I select in the transducer menu running a B164 transducer? Thanks
FishTech Obstacle Wrangler Staff member Sep 7, 2023 #2 Set it to Manual and use 50kHz - 1kW and 200kHz - 1kW
J Jcapuano New member Sep 7, 2023 #3 Can I set both at the same time or do I have to select each time I switch frequencies?
FishTech Obstacle Wrangler Staff member Sep 7, 2023 #4 Once you set that up in the menu you can view one or both frequencies at the same time. It will not go away.
