AIS and Radar targets not aligned
Wdeertz
I have a Furuno FA150 AIS transponder (updated for GPS rollover) and DRS4DNXT radar and the targets are not aligning (see attached photo). I’ve aligned the radar per the manual and when approaching objects the radar offset appears to be aligned. How close should the targets overlay? The attached photo I’d estimate the targets are about 250 ft apart when the vessel was about 1nm away.
Of the two, the radar is the most accurate. AIS isn't broadcasting every second and transmissions rate can change as it has to wait for other AIS traffic taking it's turn. A boat can move some pretty good distances between transmissions. The AIS location is also entirely out of your control. That location is what the other ship is transmitting. Some very large tankers might have that GPS at the front or the back of the boat. When they are 600ft long vessel that is some additional distance right there on top of the other factors. Radar as long as you have it properly aligned to the bow of the boat and the heading you are using is good, it the best source of the other boat's current location. If your heading data that is being used is off somewhat because a flux gate is being pulled it is just one more thing that leads to them not aligning perfectly. Sat compasses give the best option for your heading information as they are not dependant on magnetic north. There is a lot of variables to consider but it isn't abnormal to have several targets (AIS and ARPA) not be directly showing on top of each other. One must just ensure that everything is correct as possible and understand that the radar is more Realtime data.
Johnny, thanks for the explanation. I’m using a SCX20 sat compass so should have a good heading. In this example the target boat was only 25m and we were both going about 7 knots. So given the slow speeds and small vessel size I would expect a closer overlap. Both boats were Class A AIS which transmit gps location every 2-10 seconds so if we assume 7 knots x 6076 ft (ft per nm) / 3600 (seconds per hour) x 10 seconds = 118 feet, and since both vessels are moving I think we need to double so 236 ft. I estimated the difference at 250 ft so this computation seems to support the overlap difference.
I had previously always assumed the AIS targets were more accurate but based on your explanation now know to rely more on the radar. Thanks
