I replaced my GP330B with an SCX20. Heading and lat/long are spot-on, but while sniffing the NMEA2000 bus to resolve a different problem, I noticed the 'altitude' value in the SCX20 GNSS Position PGN (127029) was negative 14 meters. That is impossible since the boat is moored on a lake that is maintained at ~20' above MSL. The same sniffer (Actisense NGT-1) showed the GP330B and Mercruiser autopilot GPS receivers reporting positive 7 meters which is reasonable (~23' above MSL).
I am concerned that I specified something incorrectly in the setup parameters. The actual antenna height is 5.2 meters which is what I set. I tried zero and 10 meters but changing that parameter had no effect on reported altitude. Also, since the GPS receivers reporting +7 meters can't receive GLONASS, I tried disabling GLONASS in the SCX20, but the result was the same.
Any advice or information will be appreciated.
---rick
---rick
